STALKER: Call of Pripyat
Publisher: Deep Silver
From our
STALKER: Call of Pripyat review:
One place where STALKER: Call of Pripyat
definitely excels is in the graphics department, with fancy DirectX 11 tessellation, huge view distances and a gorgeous lighting system that really delivers in wow-factor. Pushing the game up to the maximum settings can require some hefty hardware obviously, but it’s worth the effort if you can because the technical prowess of the game is one thing that’s impossible to fault.”
We run the game at its prettiest, and most demanding, with the image quality set to Maximum and in DX11 mode. We then enter the Advanced settings menu to ramp up every slider to maximum. We leave SSAO (Soft Shadow Ambient Occlusion) at default. We repeat each test three times, discarding anomalous results and averaging the consistent ones.
For this test, we've used the
STALKER: Call of Pripyat benchmark tool, so the results aren't directly comparable to those from our
GeForce GTS 450 review.
Nvidia GeForce GTX 460 768MB (675MHz GPU, 3.6GHz memory)
Asus ENGTS450 Top 1GB (1,004MHz GPU, 4.2GHz memory)
Asus ENGTS450 Top 1GB (925MHz GPU, 4.0GHz memory)
Nvidia GeForce GTS 450 1GB (783MHz GPU, 3.6GHz memory)
Frames Per Second (higher is better)
See Page 8 for
Overclocking Analysis.
